I porting still hanging in limbo
cricketfan
Hi
Like hundreds in this forum. My porting has been stuck in between koodo and pm.
Messaged @shazia_M but she hasn't read the message yet.
Now I don't even get incoming calls. Thou outgoing and data works.
What else can be done to make this problem fixed.
2 REPLIES 2
Cyber
@cricketfan,
The only way to have your porting issue resolved is by contacting a PM moderator via private message.
Your message will be stuck into a waiting list. Be patient, you will be well compensated once your issue is solved.
Rockdaddy22
I would keep using the Koodo sim if it works. You could try facebook and twitter support.
