I need my min
01-21-2022 01:00 PM
01-21-2022 01:43 PM
No pm community support isn't very helpful when all you give is the same one line answer to contact customer support in your search for bravos and solutions.....sad really and a middle finger to every community member who actually puts the effort in to help customers.
01-21-2022 01:33 PM
Did you port your old number over to PM or did you pick a new number?
We can help you if you can give more details of your issue.
01-21-2022 01:25 PM
Could you please explain what kind of problem do you have. We might be able to assist before you send a message to CSA.
01-21-2022 01:23 PM
01-21-2022 01:18 PM
@Calib1 wrote:Everything I do won't work I need a call
back
@Calib1 - Are you a new customer?
Or, are you an existing customer that used to have working services, now it does not?
Details are needed to identify the correct troubleshooting.
Did you activate recently ?
If so, try:
- rebooting your phone
- remove and reinsert your SIM card
- is your phone locked to its previous provider, you need to contact them to unlock it
- is your phone blacklisted, check here: https://www.devicecheck.ca/check-status-device-canada/
Did your transfer a number over to Public Mobile?
If so, you need to accept an SMS text to approve the port on the previous SIM card. Insert the old SIM and wait for the text.
01-21-2022 01:05 PM - edited 01-21-2022 01:05 PM
There is no one to call you. You have the community or customer support to help you. Give us the details of your issue and we will help you solve the issue. Call 611 from your phone and tell us what it tells you.
