01-30-2021 10:53 PM - edited 01-05-2022 05:05 PM
01-31-2021 03:15 AM
If you are on the $35/2.5gb plan or less and have 10 days or preferably 7 days or less remaining choosing the $15/1gb data add on and using it sparingly might be the best choice. Any unused data will remain on your account to use to supplement your plan data the next time you run out. You should consider scheduling a plan change on your next renewal to a higher data plan if you use more than 500mb of the data add on in your remaining days before renewal.
If you have used 2.5gb in 14 days or so you should change your plan now to the the $40/5gb plan or higher as you have much higher data needs then you originally anticipated.
If you are on the $40/5gb plan or more it most economical to bump up your plan to what suits your needs and change your plan now. The exception to this rule would be the $50/8.5gb as there is no higher plan....in normal circumstances adding funds and sending a support ticket requesting the moderators renew the plan early would be in order. If you are close to renewal due to long wait times for support atm the purchase of the $15/1gb data add on might be a better choice if you really need data and now!
You should also review your data usage. Set your phone's data counter, set your data warning and limiter to better track your usage. Use your data saver and turn off all background data this wastes up to one third of data on apps doing nothing for you in the background.
01-30-2021 11:12 PM
@Watso32 wrote:I need data on my phone
You have 2 options - both can be done in self-serve or the first can also be done via *611:
01-30-2021 10:59 PM
More details are needed. We are customers like yourself. We are able to offer advice which often resolves issues, but we have no access to your account.
More details the better. New customer versus old? Which plan? Ported over? Does talk/text work? Etc.......
01-30-2021 10:59 PM - edited 01-30-2021 11:00 PM
What plan are you on? When is your renewal? How much data do you think you need?
01-30-2021 10:58 PM - edited 01-30-2021 10:58 PM
@Watso32 What plan are you on? Are you looking to buy a data add-on? If yes you can purchase it from your self-serve account or by dialing 611 if you already have cc/debit linked. See more info here on how to purchase an add-on: HOWTO: Purchasing Add-ons - Community (publicmobile.ca)
