10-12-2023 09:21 AM
05-12-2024 10:40 AM
Thank you so much. So I took the $15 plan opposed to worry about reactivating my plan every 85 day mark.
10-12-2023 09:58 AM - edited 10-12-2023 09:59 AM
You won't be able to remove the credit card yourself, but you can turn off the subscription as noted. It's recommended that you reactivate the account for one month around the 85 day mark so that you don't risk losing your number. Then you can repeat the process. And if you want you can drop your plan down to the $15 plan so that that month only costs you $15.
10-12-2023 09:37 AM
Ok, thank you
10-12-2023 09:28 AM - edited 10-12-2023 09:31 AM
Log in to your account and go to the "payments" section and remove the credit card and subscription/auto pay. Please note that the account and your number closes after 90 days of no payment.
