I have successfully reset my self serve password over five times, but none of the new passwords work
kigenyig
its almost a month i cant acess my account. old password did not work, I reset successfully the self serve password but it did not work as well, I have been trying but nothing seems to work out.
kigenyig
The Moderator team was able to help.
thanks, everyone.
will13am
@kigenyig , the password reset is broken for your account.  You are going to need moderator team support to do the reset.  The moderator team can be reached via private message using smartforms which is initiated by clicking on the ? on the lower right corner of the webpage or try using this link. The guided process will facilitate documentation of the issue or concern and the required resolution which will be submitted to the moderator team. Refer to this announcement link for additional details on smartforms and the ticketing system for moderator team interactions. Refer to the following knowledge base article for additional information on the moderator team.
kigenyig
It's not,
Before an account is locked, a warning is issued.
 So I ensure I don't lock it out. I try logging in on another day.
tsparkle21
Although you’ve successfully reset your password, your account may be locked due to too many login with an incorrect password. Reset password, remember said password and login after a couple of hours.
