12-21-2023 10:04 AM
The waiting time is 4 hours, can I have temporary number for use during this waiting period?
12-21-2023 10:39 AM
@Rebecca92 wrote:You got it! Thank you so much!
@Rebecca92 , yours welcome! Merry Christmas 😉
12-21-2023 10:39 AM
12-21-2023 10:28 AM
@Rebecca92 wrote:My phone is showing SOS , my old service is cut offline already.
@Rebecca92 , this may be a silly question but after you installed your eSIM did you do these instructions below?
Reboot your phone.
In cellular settings make sure that ‘Turn On This Line’ (for iPhone ) is selected. (I am not positive where the setting is on a different phone to turn it on, possibly ‘Turn on your eSIM under Mobile Network’), reboot your phone. (You may need to reset network settings then reboot)
12-21-2023 10:24 AM
@Rebecca92 That’s right , this is a sim provisioning issue please use the link below to contact support to fix on there end . And everything should be working as expected . You did everything right . Just a system issue with sim
12-21-2023 10:22 AM
Yes. I have been reply YES with my old phone service and then my old service is offline in a few minutes. That means the transfer is done but my public service is not available
12-21-2023 10:19 AM
@Rebecca92 SOS then this is a SIM card provisioning issue . Easy fix for support
send a private message To CS_Agents
12-21-2023 10:19 AM
I can’t use old phone service anymore. I wonder the transfer to public service has some problems
12-21-2023 10:15 AM
Yes please. Thank you!
12-21-2023 10:14 AM
12-21-2023 10:13 AM
No my old service is cut off. No phone service at all now.
12-21-2023 10:09 AM
HI @Rebecca92
there is no temporary number. can you actually make calls? during this time before porting is completed, you should be at least able to make calls
if you cannot even make calls, or cannot connect to PM network, it is a sim card and account setup problem. Please submit a ticket with CS agent and ask them to check if your account was permissioned
12-21-2023 10:07 AM - edited 12-21-2023 10:09 AM
@Rebecca92 .does your old providers SIM card still work ? If it does porting not complete . I will send you the porting team number private message . They can give you status update on the port or re trigger the port request if needed also
adding did you reply YES to the confirmation text to port number . From old providers SIM card in phone @Rebecca92
12-21-2023 10:05 AM
I believe you will just have to wait. If your eSIM transfer is complete you will see Public Mobile on your phone instead of your own provider.
