09-10-2023
02:53 PM
09-10-2023
03:10 PM
computergeek541
Hello I recently refer a new member, but I do not have a message received , it is successful. but I didn't get any point rewards yet. please advise
09-10-2023 03:10 PM
Hi @aly1
It may take a day or so for the text to come. Also, just make sure if you have zero or the letter O that the person you referred uses the correct character.
09-10-2023 03:04 PM
I had the same problem when I did it yesterday but I got the text today! It just takes time.
09-10-2023 02:55 PM - edited 09-10-2023 02:56 PM
@aly1 It’s best to get your friend to contact support to be sure it was applied correctly on activation . But they should see the $10 in their account with in 72hours of activation and you should see your $1 / 1point with in the day usually right away . But again best to confirm with support that it was applied correctly
send a private message To CS_Agents click
VVVVV Link below VVVVV
