07-11-2022
05:08 PM
07-12-2022
07:26 PM
computergeek541
I lost my phone and got a new sim, while activating the new sim I got locked out of my account. Now every time I try to log in it says:
Idk what to do or how to fix this. Please help 🙏
07-12-2022 01:49 AM
Thank you everyone for your helpful suggestion! I managed to submit a ticket following your steps. Thanks a lot!
07-11-2022 05:36 PM
@stayweird
As noted by others, you need to wait 3 hours before you can login and click on Forgot Password.
Remember to click on Change SIM Card and NOT activate your new SIM.
07-11-2022 05:28 PM
HI @stayweird you can wait 3 hours and try again
or you can open ticket with PM CS Agent
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
First type: "Forgot log in information"
Then Click "Contact Us"
Finally Click "Click here to submit a ticket"
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
07-11-2022 05:28 PM - edited 07-12-2022 07:43 AM
@stayweird hi when you are locked out for to many attempts you have to wait 3 hours for a reset if it doesn't work then, you will need to open a ticket, to speak to a customer service agent Click here or if you are having issues with Simon you can send private message to a CS Agent here: https://bit.ly/2GGCJzH
