I have a Samsung Ace II GT_S7560 M 4 in. I would like to change for a telephone with a larger screen
Bernard456
Hi.
I own a Samsung Ace II GT_S7560 M 4 in. screen.
I would like to buy a other telephone with a larger screen. Operating with my plan. $25 per month.
Thank you.
Bernard456
Thank you very much every body. I will keep my cheapest telephone and use it only like a telephone.
BetaKam
Hi there,
You can get some decent smart phones at Staples :
ZTE Grand X Smartphone, Unlocked, White
Motorola (XT1064) MOTO G 2nd Generation Smartphone, 8GB, Unlocked
I think the Motorola is the nicer one.. but both are bigger than 4 inch. And both should work with Public Mobile.
You may also want to find  a Nexus 5, I use that on public mobile and I have no complaints so far.
BetaKam
Hi there,
Cyber
@Bernard456,
To use on Public Mobile network, you can purchase a locked phone to Telus/Koodo or an unlocked one from Staples.
If you are looking for a cheap price, Kijiji would be the cheapest place.
