05-13-2022
08:55 PM
05-14-2022
12:39 AM
computergeek541
Hi,
So basically I want to pay for my mobile data plan and I forgot the e-mail linked to my phone number What do I do?
05-14-2022 08:54 PM
05-14-2022 10:09 AM
@Yaniss if you activated in-store, you may have not created a self serve yet. If so, you can register for one here:
https://selfserve.publicmobile.ca/self-registration/
Then once you are logged in, you can update/replace your credit card information here, see bottom, left corner under the PAYMENT tab:
Otherwise, go the process to contact CSA by methods already posted.
05-13-2022 09:49 PM
@Yaniss If you need to pay urgently then you could purchase a voucher from retailers like Canadian Tire, London Drugs, SDM or gas station like Shell and load the funds by dialing 611 on your phone. This gives you time to sort out your account login info.
05-13-2022 09:20 PM
This suggestion helps many of the ppl in the same boat, where they have many emails and can't remember the one they used. A search will get the answer fairly quickly
05-13-2022 09:02 PM
Hi @Yaniss just open ticket with PM CS Agent and they can find out for you and reset password
To open a ticket with PM Support, at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
05-13-2022 09:01 PM
You should also got an email from PM welcoming you to PM so conduct a search on your archived emails.
05-13-2022 08:58 PM
You will need to contact a CS_Agent if you forgot your email or password link to your phone number. They can contacted by private messaging or create a ticket via SIMon Chatbot on this Community page.
