10-03-2019 10:28 PM - edited 01-05-2022 07:24 AM
I need to purchase a new phone and I wanted to look up the compatibility with Public Mobile. This is what I received using the startup function. I'm assuming that the sub-model information has the different types per country and Band width, but I'm not sure.
Does someone understand what this means? Could you please explain it to me? Thanks!
850MHz, 1900MHz
Band12-700MHz, Band17-700MHz, Band5-850MHz, Band4-AWS, Band2-1900MHz, Band7-2600MHz
850MHz, 1900MHz
850MHz, 1900MHz
850MHz, 1900MHz
850MHz, 1900MHz
Band12-700MHz, Band17-700MHz, Band29-700MHz, Band5-850MHz, Band4-AWS, Band2-1900MHz, Band7-2600MHz
850MHz, 1900MHz
10-04-2019 10:34 PM
10-03-2019 10:39 PM
@NB-Pub All listed by you will work but usually you should know which you have.
10-03-2019 10:31 PM
Sub model is the model of the phone sold in different countries.
Public Mobile uses the following frequency bands:
Most of the submodels would work with Public Mobile.
