01-29-2021 11:41 PM - edited 01-05-2022 05:04 PM
some one stole my phone yesterday an now I'm stuck trying to get my new SIM card working how do I get my phone number that I already have
Joining Public
01-30-2021 07:36 AM - edited 01-30-2021 07:39 AM
Hello @charlesdnewman3 ,
EDIT - i did not realize another thread was already started. Seems that first one has your answers in it - Good Luck!
Why don't you have access to your SELF SERVE account: https://selfserve.publicmobile.ca/?
Is your password not working? Try the "Forgot my Password" option if this is the case.
If this still does not work, then only the moderators can get you back in, follow @Triguy methods to contact them.
If you are saying your phone as a SIM in it, report your phone lost/stolen:
- Log into your Self-Serve account
- Go to Plan and Add-Ons > Lost/Stolen Phone
- Select Resume/Reactivate Service
If you are saying you already purchased a new SIM, then once you get into your SELF SERVE account change your SIM number as @Triguy shows.
Found under "Change Sim Card":
01-30-2021 07:22 AM - edited 01-30-2021 07:26 AM
Are you able to log into your account ? If you can log in then you can change your sim..
Once you receive your new SIM card, you can change the SIM card number on your account and reactivate your service via Self-Serve by following these steps:
- Go to Plan and Add-ons > Change SIM card
- Enter your new SIM card number into the field. Your SIM card number is found on the back of your SIM card.
If you still need assistance then submit a ticket to a moderator.
Here’s when and how to contact the Moderator Team:
- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
- Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
01-30-2021 07:06 AM
01-30-2021 05:28 AM
yeah I just bought a new SIM to replace the stolen one @darlicious
01-30-2021 02:50 AM - edited 01-30-2021 02:51 AM
So let me get this straight....You went to a store and had them activate a sim card. Did you choose a new number or port a number in? Did you put the pm sim card in your phone and then your phone got stolen? Or do you still have the pm sim you activated? Or have you bought an unactivated pm sim card to replace the now stolen one?
01-30-2021 02:04 AM
@charlesdnewman3 :Maybe when you bought your phone at the store in first place they didn't create a self serve account for you, so try using your email and try the create account button in the self serve portal by click those the lines in to right corner.
01-30-2021 02:01 AM
@charlesdnewman3 : Then all you can do is wait. By default, you'll get an email notification. Don't answer that. Come back here and click on the little envelope in the upper right next to your test tube avatar and then click on the subject line to fully open the message.
01-30-2021 02:00 AM
@charlesdnewman3 wrote:I gave them my email an 4 digitt pin
Contact a moderator for assistance.
01-30-2021 01:52 AM
01-30-2021 01:50 AM
store
01-30-2021 01:40 AM - edited 01-30-2021 01:41 AM
@charlesdnewman3 : When you first started with Public Mobile did you activate in a store? Or yourself online? If in store then yes you're in a bit of a pickle where you'll need moderator help.
If yourself then you will have created an account. You would have chosen an email address that will have been the log in username.
01-30-2021 01:36 AM
no i have tried logging in an it says that there is no account
01-30-2021 01:27 AM
@charlesdnewman3 : Can you log in to the account that you already have? If so, use the above instructions. If not, try the Forgot your password? link. If still not then you'll need to contact the moderators to get you access to your account. Then again follow the instructions.
01-30-2021 01:23 AM
if only it was that easy like I said my phone was stolen so for one I don't have a phone to get the 6 digit pin that they text you to move on to making a self serve account so yeah now what
01-29-2021 11:53 PM
@charlesdnewman3 :As HALIMACS above said, log into your self serve account and choose change SIM card option.
Press those the lines in top corner, choose my account then log in. Next choose change SIM card and enter your new SIM card number.
01-29-2021 11:52 PM
@charlesdnewman3 wrote:help me please I'm just so frustrated with this rite now
Here you are..
(sorry, Change Sim Card is broken into 2 lines on my screenshot
Change_SIMCard
01-29-2021 11:50 PM
Please see my earlier reply @charlesdnewman3
01-29-2021 11:45 PM
01-29-2021 11:45 PM - edited 01-29-2021 11:52 PM
Log into your self serve account and under My Profile, select the "change SIM card" option.
After entering the new SIM card number, insert the SIM card into whatever compatible phone you plan to use.
01-29-2021 11:43 PM
