01-08-2023
05:49 PM
01-08-2023
05:56 PM
computergeek541
01-08-2023 08:33 PM - edited 01-08-2023 08:34 PM
So you can't recieve any messages? On wifi or with mobile data for iMessage? You have SMS/MMS enabled in your settings and you cannot recieve them either? When's the last time you updated your iOS software? Connect to wifi or iTunes and check for software updates and update your carrier profile.
01-08-2023 08:03 PM
Thank for for your helping.
I try to all useful way from everyone, so I couldn't receive any message. I use apple phone and I can receive any message near few days.
01-08-2023 06:58 PM
lol not yet, he's old school, learning ....
01-08-2023 06:47 PM
@yackinlyn no, the trick i mentioned above was just to send.
To receive iMessage, he has no choice but to use Wifi or Data
Didn't get get the 2GB data from Christmas? already used up that as well?
01-08-2023 06:41 PM
got it, thx, how can he know the other sends him Imessage?i remember some forum talking about this
01-08-2023 06:20 PM
@yackinlyn your husband can hold down on the message that not delivered (since there is no data) and then click "Send as SMS" to send via sms instead
01-08-2023 06:12 PM
my husband has no data ,he can only receive Imessage under wifi, does your freind use iphone and enable imessage? if so, turn on your data ?
01-08-2023 06:11 PM
Maybe a little more info?
01-08-2023 05:57 PM - edited 01-08-2023 05:58 PM
Try adjusting RCS services, then try texting again:
If Android, try adjusting Chat messages options.
For Apple, adjust the iMessage settings:
01-08-2023 05:51 PM
@Mia123 did you just join PM today?
or you have been with PM for some time and just start having sms issue today?
and incoming and outgoing voice calls are working?
First, try to Reset all Network and see if it helps
If possible, put your PM sim card in another phone to test it out.
if you don't have another phone around, try to reseat the sim card (power off the phone first ,take sim card out for a minute, then put it back in and power up)
