09-04-2021 08:41 AM - edited 01-06-2022 03:23 AM
09-04-2021 09:10 AM
If above suggestions don't help,
Have you tried reseting your password.
https://selfserve.publicmobile.ca/forgot-password/
(Check your junk folder)
If not working, you will need to customer service agent (CSA).
You will need to contact customer service agent (CSA):
Click on the chat bubble icon on the right lower corner of website to start ticketing process to contact CSA. Type: I can't login. Follow the prompts to submit ticket.
Response times can take a few hours. Check your private message inbox (envelope in upper right corner of website).
09-04-2021 09:10 AM - edited 09-04-2021 09:11 AM
Try using a different browser and incognito mode. Also try clearing your cache and cookies then reboot.
If you still need assistance then submit a ticket.
Here’s when and how to contact our Customer Support Agents:
09-04-2021 08:50 AM
@majiepastor wrote:In tried forgot pw but still i cant log in..
Is your account currently suspended?
After 90 days of suspended/non-payment status, your account will be permanently deactivated, which means you will:
1-Lose access to your phone number (and Self Serve account), any rewards or Available Funds balance that was in your account at time of suspension, and won’t be able to transfer the phone number to a new provider in the future.
2-Need a new Public Mobile SIM card if you decide to activate a new Public Mobile account.
09-04-2021 08:47 AM
We're you unable to answer the security question or did you reset and still couldn't log in?
