09-16-2021 02:57 PM - edited 01-06-2022 03:23 AM
I am using Find a Friend to ‘see’ my daughter while at middle school, new school for her. Would tracking her be a part of ‘data’ used for her?? Hope I’m making sense 😊
Service
09-26-2021 04:11 PM - edited 09-26-2021 04:11 PM
Tracking needs data to send and receive. if the phone are connected to WiFi which most of the schools now have, Also, the location services should be enabled.
09-26-2021 03:33 PM
Is "find a friend" the same as sharing your location with others in your timeline? If so it does require data when it's not shared via wifi but it is minimal.
09-26-2021 03:18 PM - edited 09-26-2021 03:19 PM
@Shayla1
I know this is 10 days old but wanted to clarify that we are talking about the daughters phone and data while she is at school. Assuming so…. Wouldn’t most schools have wifi for students now? I don’t know, it has been a LONG time since I was at school… Al Gore hadn’t even invented the internet then (joke to weed out the youngsters). So my point is, if they DO have wifi that the daughters phone is connected to while at and around school, cell plan data use may not be very much.
AE_Collector
09-16-2021 03:36 PM
Yes you will need a data for that device to tracking GPS....
09-16-2021 03:08 PM
@Shayla1 yes, all these tracking app needs data. It needs data to send back the location
09-16-2021 03:08 PM
@Shayla1 : Yes. The GPS is one way. Then the phone sends that location data back to servers that you can then retrieve for your purposes. It should also work with wifi. Try one or the other to see.
