6 hours ago
I have Public Mobile phone number for almost a year. I wanted to change the plan but no emails were linked to the phone number (which is weird for me). I have created the account but not sure how to link the phone number to the email.
I wasn't able to create a ticket as well
6 hours ago
I did it. When I click Forgot email I got the message that no emails associate with the phone number
6 hours ago
if you only have used PM service for a year, you would have for sure used an email to setup the account. Use the Forgot Username link on the login page, and PM will send you an email to the correct mailbox. Search all your mailbox for that email from Forgot Username
6 hours ago
HI @Mihael
if you don't recall setting a an email login for My Account, you will need PM support agent to help. Please message them here
6 hours ago
I do not have an app on my phone
6 hours ago
Thanks! I will send the message
6 hours ago
@Mihael if you go to your PM app on your device go to the Account tab and then go to Manage Eversafe ID, there you should be able to see which email address you have linked and you should be able to change it
6 hours ago
@Mihael You have to have email associated with your PM account . If using the forgot email option didn’t work . You can get support to help figure out the email you used to create the account
