Monday
I have US/Canada plan. When opening phone - trying to call - network gets selected AT&T and I immediately getting busy signal when trying calling any number. Data is working but calls are not whether I am on wifi or not. What should be done? Using android phone. Also no one can reach me either by phone.
Monday
@hTideGnow wrote:please note due to the end of 3G in US , some phone might not receive and make calls in US. Only phones VoLTE whitelist can recieve calls on the LTE network. Check if your phone is on the list here:
https://www.publicmobile.ca/en/on/get-help/articles/volte
Having a phone that doesn't have VoLTE wouldn't cause a busy signal. When threre's a busy signal when tryng to call, that means that is actually a voice network availiable.
Monday
hi @Viktor007
what phone do you have? But your mobile data works?
if your phone not on the list, you need to use a workaround to make calls. dDownload VoIP app TextNow and then use the app to make and receive calls
