2 hours ago
I cannot update my payment method.
August 5 - I tried to update my payment method because I could not make or receive calls. The system won't let me change it and I cannot make or receive calls at all.
an hour ago
Yes, the location was on and the credit card is a Canadian one. the postal code is the same with the credit card.
an hour ago
@Passaporn I tried via PM app but got the message "Credit Card validation failed. Please try again."
Did you make sure that location was turned on? Does the postal code on the credit card match the one on your street address? Presumably it's a Canadian credit card?
2 hours ago
@Passaporn, if you're still stuck with no service you can open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
2 hours ago
@Passaporn If you tried to many times you may have been locked out and need to wait one full hour before trying again . In some cases you might have to wait 24 full hours before trying again . But also note of your in a hurry you can buy payment voucher from shoppers drug mart and load it *611 and resume services right away until your able to update the credit card info
2 hours ago
2 hours ago
@Passaporn Are you using the website or the Public Mobile app? If not using the app, try it and make sure to have location services enabled.
