05-30-2023
11:58 PM
05-31-2023
08:06 AM
computergeek541
Hi,
I cannot make calls or text. When I look at my phone screen it says "No Sim Card" However I have a sim card.
I have restarted the phone. Removed and put the sim back in the phone and still no luck
Is there a way for you to confirm the status of my phone connectivity or fix it on your end?
05-31-2023 12:38 AM
If you recently ported your number over to PM. Did you reply to the text with YES confirming you are porting over to PM? There is a 90 minute for you to reply or porting will be cancelled.
It sounds like either you missed replying to the text. If you did reply then it is a backend issue with your SIM and will need to contact a CS_Agent help you to complete your porting.
05-31-2023 12:07 AM
Hi @tiekwan
if yours is not a new activation, then it sound like more a device problem
Can you put another sim card, working one from another carrier , into your phone and test?
or test your sim in another phone
05-31-2023 12:01 AM
