I can't use my data
08-30-2017 01:30 PM - edited 01-04-2022 02:35 PM
08-30-2017 06:28 PM
If you've tried restarting your phone and that didn't work then check that you actually have mobile data enabled in your phone (check your phone settings).
Failing that, check your APN settings:
Setting Up Data (APN) On Your Phone
If that doesn't work, send a private message to the moderator team (click me!) with your phone number, email address and a description of the problem and they will look and ensure that the plan has been correctly applied. 🙂
For what it's worth, sometimes I've swapped SIMs between phones and if data wasn't working afterwards it has been the wrong APN setting.
08-30-2017 06:06 PM - edited 08-30-2017 06:10 PM
Why don't you switch to 18GB/90 days with 3G speeds? Imo the bigger limit is better then faster speed since 2.5MBps should be still very usable. The problem is probably your APN settings. The 18GB/90 days is also cheaper it's $156 over 90 days so $52/month.
08-30-2017 04:19 PM
buying an add-on is a two step process. you buy it first, which gets money from your card. then you buy it again using the loaded money. Did you do that?
08-30-2017 01:43 PM - edited 08-30-2017 01:43 PM
1. Try rebooting your phone? What message appears on the phone?
2. Login to your account and confirm the plan is correct and that a data add-on is showing under Add-ons?
3. Is this a new account and you requested transfer of your number from another carrier?
4. What is make/model of your phone?
