09-23-2023 08:17 PM - last edited on 09-23-2023 10:26 PM by computergeek541
I can’t transfer an eSIM to a new phone. Apparently I need to buy a new eSIM, besides being an absurd money grab. They is no way for an existing account to buy an eSIM.
it only gives me options to change my plan to a more expensive plan
I tried to contact support and the support site is just an error message
09-23-2023 08:30 PM
hi @Stopit
yes, you need to use the app to buy new esim
download and install the app on the new phone. Login and select Subscription & addon and click Shop Sim card button and select esim to buy
09-23-2023 08:21 PM - edited 09-23-2023 08:22 PM
Hello! Yes unfortunately ESIM’s are not transferable from one device to another. If you want to use an E-SIM on your new device you must purchase one using the app on the device (go to subscription and add-on’s and then hit shop SIM card now) and have it added through direct download within the app or add it to the device using the QR code. You could purchase a physical sim from Amazon, a local telus location, or directly off of the PM website and then add it to your profile. This would give you the freedom to change the SIM between devices without any further charges.
If you wish to contact support you can do so.
Please click this link below to message customer service:
Keep an eye on your mailbox here as that is where your reply will come in (envelope icon on desktop, click your avatar icon in the corner and then click messages if on mobile).
09-23-2023 08:20 PM - edited 09-23-2023 08:24 PM
@Stopit yes it’s $ grab , but Yes you can on the new phone log into the app and go to subscriptions add on page notice shop sim at the bottom select it and choose eSIM download and install it and your done
