a month ago
It's been a few weeks I can make a call but I can't receive calls, it goes directly to my voicemail. To solve the issue I reboot my iPhone 7 and the problem is solved for a few days or a few hours. I searched the community and I found out the iPhone 7 is not supported for VoLTE.
OK, last weeks I bought a brand new iPhone SE 3rd gen in Apple stores. Unfortunately, it didn't solve the issue. I still can't receive calls. A reboot solved the issue but not for long. The setting is Voice & Data LTE. What can I do ?
a month ago
I think the CSA got the problem, here's the solution,
"Please go to Settings of the iPhone, then Focus, Do Not Disturb, then turn it on. After that press People and ensure that the option Allow calls from is set on Everybody/All.
Then you can turn off Do Not Disturb, restart, and test."
a month ago
OK I'll update the ticket, Thanks.
a month ago
HI @Sergio88pm
I think you need to ask agent to check agian
you can reply on the same old ticket and ask them to do what the did again, and check why it fails again
a month ago
Unfortunately the problem is back. They didn't resolve the issue.
a month ago
They made a network refresh. I'll check in the next few days if the problem comeback.
a month ago
Good idea but no call forwarding.
a month ago
@Sergio88pm can you check your call forwarding settings? Maybe you have accidently set it up?
a month ago
The chat didn't understand my message. "I can't receive calls, it goes to my voicemail." They should hire chatGPT. Anyway, I was able to open a ticket.
a month ago
You're welcome. Let us know how it turns out.
a month ago
Ok thanks, I'm with PM chat
a month ago
@Sergio88pm Use the chat icon bottom right of this page to create a ticket, if that doesn't work send support a private message using this link
a month ago
Five years at least with PM, how do I create a ticket ?
a month ago
@Sergio88pm In Canada not having VoLTE shouldn't be a problem as we still have 3G networks here, unlike the USA where it would be a problem. Best to contact customer service at the chat icon bottom right of this page.
a month ago - last edited a month ago
Hello @Sergio88pm
If you just ported over, your port may not have worked. If you did just port over, if you place your old SIM card back in, is there still service?
If you've been a long time customer and you're having these issues, it seems PM needs to reset your network. Here's how to create a ticket.
To Submit a ticket, please click the following link to access the Public Mobile Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type: Customer Service Agent
IMPORTANT INFORMATION: I am not a Public Mobile employee. I am a customer just like you. Please do not send me a private message with your personal information.
