3 hours ago
I'm in Alberta (587 area code) and when I try to dial other area codes such as 604 or 250, I either get dead air or a 8B1 error code message. I have Canada-wide calling and according to my profile, have 98 minutes remaining this month. I also tried cutting a ticket through Public Mobile's system, and that didn't work at all.
2 hours ago
i would ask PM to check your account then. Just open ticket with them using the Orange Chatbot icon on lower right, start typing Submit ticket, choose Contact Us and then follow the screen to login and submit ticket
2 hours ago
HI @davejmoore
if you have another phone, try the PM sim there, this will refresh the account and would work
if not, you will need to ask support agent to help.
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
2 hours ago
@davejmoore, if the suggestions shared do not help you can open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
2 hours ago
Rebooting the phone didn't work - any other ideas?
2 hours ago
Also, try calling within the 1, some reported that without 1 actually works
2 hours ago
Thanks - I did dial 1 first, but will try rebooting now
2 hours ago
HI @davejmoore
Long distance calls could be tricky. Please reboot the phone and try making the calls again
2 hours ago
Reboot the phone first
and make the call with a 1 in front
