3 hours ago
I think there are glitches and discrepancies in the app and desktop website.
I can see the $23/6GB/30d plan if I try to make a plan change in the PM app (note that I actually want the $22/90d plan, which I've highlighted in yellow below in the left screen shot. However, at no point do I get to change to the $66/90d plan (see middle and right screenshots):
Normally, in the app (and only in the app -- not the desktop site), you would see an option under the upcoming change, where you can choose a different plan. Here's an example from earlier, when I selected the $21/30d plan, and then had the option to get the $57/90d plan (which I've highlighted with a red box -- if you tap on that link, you are asked to confirm):
The desktop version has a slightly different workflow, where you can choose the 30d or 90d variants, if it exists. For example, here's a $45/30d plan, but you can choose the $102/90d variant before moving on:
The problem is, the $23/6GB plan only shows up in my app, and not when I log into my account from a desktop browser, so the workflow to select $23/30d vs $66/90d isn't provided.
Please withhold any canned responses about contacting a mod.
2 hours ago
I tried to get the 90 day plan but no options for opting it, and it gave me 45/ m instead of 102/3m, can i still get it
2 hours ago
@slusagm wrote:i wonder if browser cache problem
but if app works, schedule plan change there and go back to web and check couple days later
I'm pretty sure it's not a caching problem, as I typically do things in an incognito browser. Also, I did schedule the future change days ago, but it remains the same in both desktop browser and app, so it's likely a coding issue on PM's end.
2 hours ago
@CalgaryBen Sorry then in that case I would just do as @slusagm suggested change it on the app screen shot it for proof for support should anything go south on your renewal day
3 hours ago
@Handy1 wrote:@CalgaryBen I think you just have to hit chage on renewal date then the option for 30 days /90 days plan becomes available to choose and again confirm change on rewewl
In reference to my first (top) screen captures, I did tap on "Change on Renewal Date" but no further prompts are provided to choose the 90 day version. In the app, this is normal, and it's on the pending scheduled change where you can select alternates. With this plan, however, the option isn't provided.
3 hours ago
3 hours ago - last edited 3 hours ago
