2 hours ago
Subscription is up to date. I change the SIM card in to another working phone. Still it does the same. I am receiving calls with no issues. Texting works both ways. But can not make phone calls.
Restarted the phone, took the SIM card clean and reset. Nothing works yet. Please help
2 hours ago
I am having the same issue too
2 hours ago
i am having the same problem got a messaged saying it was fixed but clearly it is not i have turned off the phone turned on and removed sim card and did reset network settings and none of that works
2 hours ago
it is an issue with Telus. They said they were working on it. I received a text that it was fixed, but it is not. I still cannot make outgoing calls. I was given a link earlier by someone on community that gives me text message updates from Telus.
2 hours ago
I am having same problem
2 hours ago
log in to your account to just confirm that. If you have limited calling minutes, you can either wait until renewal OR...get a $5 / 500 minuites of in Canada calling add-on. So...what plan do you currently have ?
2 hours ago
unlimited outgoing..
2 hours ago
No I have unlimited outgoing. Thanks
2 hours ago
do you have one of the plans with limited outgoing calls ? Mine is the $15 Plan with 100 minutes only outgoing...unlimited incoming.
