I bought US add on but it won't activate?
Joelle2
I bought US data roaming but it won't activate.
@Joelle2 - ensure your public mobile plan is Active. Addons will only work on an Active plan.
Try restarting your phone, or perform a reset of the device's network settings to help connect to the proper network while in the USA.
See Roaming Get Help article for additional info. here: U.S. Roaming (publicmobile.ca)
DDM69
Search how to add a US package.  You'll need to make sure you add funds to your account to cover the cost of the added package.
Good luck! 😁
HI @Joelle2   first, did you check if the US add-on shows up on your My Account?
And what kind of roaming add-on ? Talk? Text? Data?
Did you see it connected to T-Mobile or AT&T?  Try to connect both and see which one works
If you have roaming data, make sure you enable Roaming Mobile Data on your phone seetings
MrSpock
@Joelle2 hi assuming you are in the US now did you manually set your network to ATand T or T Mobile?did you reboot your phone?
