I am travelling outside canada,will i still be able to receive calls on my phone?
Diavel98
hairbag1
@Diavel98
you could download free voip app like TextNow. You can send / rec free calls / text most any US and Cdn number using your local wifi or separately purchased data. Wifi is widely available almost worldwide now...you might have to ask for their password maybe.
HI @Diavel98  if you travel to US, you have a choice to buy roaming add-on to continue the service in US
but if you travel elsewhere, there is no roaming service at all so you won't get calls or service
HALIMACS
@Diavel98
Outside Canada, you can only receive calls on your phone in the US (with your public mobile service) if you have a Canada-US plan or you have a US roaming add-on which includes calling.
SourDude1234
Hi @Diavel98, you are going to have to get a local number if you are travelling internationally. You can use third party apps such as Fongo as well. PM can only serve US and Canada.
