06-20-2022 03:21 PM
06-21-2022 02:11 PM - edited 06-21-2022 02:18 PM
If it works with your SIM card that's all that matters and it's most likely unlocked. But if you want to make sure in case you want to change Mobile provider then go to settings --> about ---> at the bottom see Carrier Lock and if it shows No SIM Restrictions then it's unlocked.
06-20-2022 03:45 PM
@CountyDownIeUk thanks for that me forgot 🙂
06-20-2022 03:31 PM
@landphil99
Go to settings, general, about. Scroll down a bit. Does it say "Carrier Lock......NO SIM restrictions"?
If yes....it is unlocked.
06-20-2022 03:22 PM
@landphil99 do you have a public sim to try in it? what provider was it with last?
