05-07-2023 09:40 AM
I recently changed to public mobile and I still cannot receive phone call on my phone
05-07-2023 03:18 PM
Yup. check your private message box.
05-07-2023 03:04 PM
I am having a similar issue as above, in Port Limbo with Chatr, and trying to bump up a request with PM to resend Chatr the request to port my number. Are you able to send me this number to assist with porting? Thanks!
05-07-2023 10:47 AM
What about incoming texts? data work?
It might be a stuck port, but we need more information. Maybe check your old carrier SIM card to see whether that works.
05-07-2023 10:24 AM
What model phone do you have? If it’s an iPhone 7 or earlier you will have issues.
05-07-2023 10:04 AM
did you reply yes to the port authorization text?
I’ll send you a number to assist with porting.
Check private message by tapping the envelope icon upper right.
