03-10-2020 05:20 PM - edited 01-05-2022 11:06 AM
03-10-2020 08:46 PM
@JBodnoff Try using the manual amount option if making a one time payment.
03-10-2020 08:04 PM
@Andrew77 wrote:I put in my voucher and it's not bringing me to summery
There may be a delay in topup voucher activation depending on where you purchased your voucher. Was the cashier said anything about how long to wait before you can use it?
03-10-2020 06:05 PM
@Andrew77 try using 611 to apply payment from your phone. Here's a guide on how to use the 611 system https://productioncommunity.publicmobile.ca/t5/Self-Serve/611-IVR-Menu-System/m-p/289352#M20315
You can also use this voucher catalogue to better compare your voucher https://productioncommunity.publicmobile.ca/t5/Paying-for-your-service/Voucher-Catalogue/m-p/479165#...
03-10-2020 06:01 PM
03-10-2020 05:54 PM
@JBodnoff If the system is not accepting your credit card, keep this advice in mind.
Your address must match the billing address of the credit card exactly. Don't use the Apt.#/Unit# field. Use a 6 character postal code (X1X1X1), no space. Don't use special characters like # or &.
03-10-2020 05:24 PM - edited 03-10-2020 05:24 PM
@JBodnoff more details would be helpful. Thanks. What payment are you referring to ? Exactly what is the problem with processing the payment?
