05-09-2020 12:48 AM - edited 01-05-2022 10:43 AM
05-14-2020 01:50 AM
Thank you for your reply !
05-14-2020 01:47 AM
Thank you for your advice!
05-09-2020 08:01 AM - edited 05-09-2020 08:06 AM
@Haru the Canadian version is fully compatible. The Global version does not support 4g LTE. In places with only 4g LTE data. You will not be able to access data. If you have the global version. It will work. You will also not receive any emergency warnings. Welcome to the community. Stay safe. See below
https://apn-canada.gishan.net/en/apn/public-mobile/huawei-p30-lite
If you are a new customer and about to activate. Here's 4 articles on activation and porting and the Refer a friend reward if required:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
3.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
4. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
If you need a SIM another option is to buy your SIM card from Canadian cell supplies https://canadiancellsupplies.com/collections/latest-products/products/public-sim-card
Do it on Sunday for an additional 40% discount https://canadiancellsupplies.com/pages/discount-codes
05-09-2020 03:28 AM
That's only one version. There are many and we weren't told which one he has.
05-09-2020 03:06 AM
the phone covers a wide range of bands 4G LTE FDD: B1 / 2 / 3 / 4 / 5 / 7 / 8 / 12 / 17 / 28 / 66
3G WCDMA: B1 / 2 / 4 / 5 / 8
2G GSM: B2 / 3 / 5 / 8
It will work, and you have 4gb of ram powerful phone. Welcome to Public Mobile
05-09-2020 01:03 AM
@Haru If you purchased that phone in Canada then it's compatible and will work without any issues.
05-09-2020 12:59 AM - edited 05-09-2020 01:00 AM
@Haru yes PM is fully compatible. I have the p30 PRO and they are similar. if you check if your phone is compatible in the Telus network then you will always know if it is compatible with Public because it runs on the Telus network.
Make sure to unlock your phone before switching and dont cancel your plan with your previous provider if you want the same phone number.
cheers
05-09-2020 12:53 AM - edited 05-09-2020 12:53 AM
@Haru wrote:Is compatible with Huawei P30 lite?
I should hope so being the same phone.
Oh...you mean compatible with this place. Yes it is.
But post the exact submodel and we can help verify.
