Huawei Nova 4
10-19-2020 10:15 AM - edited 01-05-2022 03:48 PM
10-19-2020 11:27 AM
@rameenasif1303 Check your phone's specs; it must be able to use PM's network frequencies.
Network Frequencies at PM
- 4G LTE/LTE Advanced: 700 MHz, 850 MHz, 1900 MHz; 2100 MHz downlink with 1700 MHz uplink (AWS). PM throttles speed on these to 3 mbps.
- HSPA (3G): 850 MHz, 1900 MHz (UMTS). N.B. Must have these for calls to work. Texting and data also work on the 3G frequencies.
10-19-2020 11:26 AM - edited 10-19-2020 11:28 AM
that phone should work with PM network...just make sure it's unlocked and not blacklisted. Be wary of purchasing a used phone on kiji or craigslist.
Go to the top of this page, click Get Started, then scroll down to find compatibility section. In there, you can also use the tool to see if the phone is reported lost or stolen.
Good luck and welcome to PM.
10-19-2020 10:25 AM
It should be compatible but make sure you have the North American version.
