Huawei Mate 10 Pro
Colleen_O
Does anyone know if you can use a Huawei Mate 10 Pro with Public Mobile. This model doesn't show up in the compatibility checker. See the attached screen capture. Thanks.Screen Shot 2019-06-19 at 12.52.58 PM.png
Colleen_O
Just to update this thread: The phone is working fine with Public Mobile. Thanks to everyone for your answers.
Ajison
I have a huawei p20 lite and it has the same LTE bands as mate 10 pro. It works well with PM network. So I am pretty sure mate 10 pro will work as well.
hairbag1
Should work fine at PM.
Your phone...
 GSM / HSPA / LTE
2G bandsGSM 850 / 900 / 1800 / 1900 - SIM 1 & SIM 2 (dual-SIM model only)
3G bandsHSDPA 800 / 850 / 900 / 1700(AWS) / 1900 / 2100
4G bandsLTE band 1(2100), 2(1900), 3(1800), 4(1700/2100), 5(850), 6(900), 7(2600), 8(900), 9(1800), 12(700), 17(700), 18(800), 19(800), 20(800), 26(850), 28(700), 32(1500), 34(2000), 38(2600), 39(1900), 40(2300)
Triguy
Check the phone specs.
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
Please note that this information is indicative only. Your phone's compatibility with our 4G or 4G LTE networks is based on the radio frequencies of your phone. Public Mobile does not guarantee that your phone will work on our mobile network.
