09-16-2023 01:27 AM
Hi
I lost my sim card several month but public mobile withdraw automatically from my credit card. When I try to login to my public mobile account they sent a code for verification to my lost phone. How can I access to my account to report sim card loss and get a new sim card and access to my phone numebr.
09-16-2023 02:35 AM
Just wondering if you created a Eversafe ID yet? If you didn’t, you need to create one before trying to login to your account.
Once you created an ID, just click on Resend Code/Didn’t Receive Code then you have the option to have the 2FA code sent to the registered email, call or text your number.
Once you are in your account, you can either report lost phone or replace the SIM card number.
09-16-2023 02:17 AM - edited 09-16-2023 02:18 AM
if you don't have the Send email option for the security code, try these workarounds
If none of those workarounds helps, please open ticket with support by direct message here:
09-16-2023 01:29 AM
Did you previously set up the new login system? If so then you can use the Didn't get code link to get a code via email.
