How to unlock my account
mkciu
I got my account locked, can you unlock it.
@mkciu
Try clearing your cache, cookie and go incognito on your browser.
The are no time delay to re-login to your account.
@mkciu   there is no more account lock issue with My Account now
So, if you know your password, close the browser and relaunch and try again
or if you do not remember your password, try to use Reset Password there and try to reset it
if that does not work, please open ticket with CS agent
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
Quirion620
Hi there, you must use the forgot password link and go trough the process.
Yummy
You can try to log in a few hours. If it does not work contact agent for assistance.
Public Mobile has web page cache issue so you might be looking at obsolete status. Click on little spinner refresh icons lower down. Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
