How to test to see if I'm getting my 2 step verfication sms
MizzMiche
Hi there, I had an issue where I wasn't receiving any 2 step verification codes from anyone (including Public Mobile). I opened a ticket and they said my problem should be resolved in 24 hours and to turn off/on my phone and then to check to see if I am receiving them. Does anyone know a way that I can check for a 2 step sms verification code in my settings on my Public mobile account?
MizzMiche
Very helpful and it worked! Thanks so much
Yummy
Log in from another IP (go to store or coffee place with free WiFi) and PM should send you 2FA right away when you try to log in.
fixin1
@MizzMiche - Login from an unknown device or from another browser / the app.
Rastin
You could try to respond to another post here other then your own. As I get them anytime I respond to anyone here. You don't haft to post anything just try to reply
