10-29-2023
11:28 AM
08-17-2024
10:48 PM
computergeek541
Submit a service ticket sends me to 404 page.
Message to CS_Agent results in http error.
08-17-2024 10:47 PM
self solution removed
08-17-2024 09:36 PM
your message has a HTML code. did you copy and paste something in your body text message? if there is a HTML code in your text than you get this error.
10-29-2023 06:02 PM
Knocking it down from 5G to LTE seems to have solved the original problem. Still not sure why I couldn't submit a ticket but I'll take the win!
10-29-2023 06:00 PM
Las Vegas
10-29-2023 04:23 PM
@CaptainChaos wrote:T-mobile does not appear as an option. Trying LTE as network mode.
Thanks.
Where are you in USA ?
10-29-2023 12:21 PM
Yes.
10-29-2023 12:21 PM
Thanks.
10-29-2023 12:14 PM
@CaptainChaos you could try opening an incognito/private tab and try again, but yes that html message may be fixed if you remove links/hyperlinks, or just try the message again in a different browser perhaps.
10-29-2023 11:39 AM
good catch @hairbag1
@CaptainChaos , and did you try to connect to both T-Mobile and AT&T? set the network mode to 4G
10-29-2023 11:33 AM
do you have Roaming Data enabled in your settings on the phone ?
10-29-2023 11:31 AM
When I get similar HTML warning I just refresh page or click on 'post' again.
If you are opening a ticket I suggest you provide WAY MORE details then just 'please help'.
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Just type ‘ticket’ and follow prompts. Having a ticket is preferred way to contact agent as they might respond faster then receiving personal mail.
If opening a ticket does not work very first time, contact agent directly: send a private message to the CSA - agent by clicking (Ctrl+) Here
10-29-2023 11:29 AM
just try again, best to type out the message. The error usually there because of people copy and paste and some hidden HTML code there
and you can use this link as well
