07-06-2025
01:08 PM
07-06-2025
05:18 PM
computergeek541
i was able in the past to send a sms to my phone using the number@msg.telus.com
format but it dont work any more
is thre a new version of this or a phone setting that needs to be turn on ???
please help
edited by computergeek541: changed category label (discussion unrelated to Community category)
07-06-2025 01:25 PM
Thanks so much
it worked
from my outlook on my computer i selected plain text and it took 3 sec and it was on my phone.
07-06-2025 01:14 PM
did you try these domains:
07-06-2025 01:10 PM
yes, the email is correct
but you cannot use fancy email desktop app/program to send, you need to use either the web version , which will send plain text--like send from Gmail via browser, or set to send as text if you have the option with the desktop program.
