09-07-2024 11:43 PM - last edited on 09-08-2024 01:09 AM by computergeek541
In the web layout, it does not seem to be possible to remove credit/debit card information. It is possible to update card information, but apparently not to completely remove. Or am I not seeing this option to remove credit/debit card. I don't want to update my card information.
09-09-2024 11:43 AM
You can buy a prepaid credit card or use one that has no funds left. So do the change option and set up your account to be paid from the prepaid credit card. Then use the card to buy gas.
It will cost you a fee of around $5.
09-08-2024 10:00 AM
You have to open a Ticket and ask agent to delete your payment info.
09-08-2024 12:25 AM
@Saji14 you are correct. You cannot remove the credit card info yourself. Only a public mobile agent can do that. Use the chat orange bubble lower right to create a ticket and ask them to remove it for you.
09-08-2024 12:14 AM
Hi, I don't think that they have the "remove" option, I think all you can do is turn off the subscription option so that they won't renew your plan next month.
