12-03-2023 06:46 PM - last edited on 12-03-2023 09:30 PM by computergeek541
I need to put my SIM as lost/stolen… when I follow the instructions on the website it says to go to “my account” and then the “profile” tab…. There is no “profile” tab I can find.
12-03-2023 07:02 PM
@hairbag1 For me it's a > in Safari on iPad and a + in the app
12-03-2023 06:58 PM
@Phil_Adelphus wrote:@dustymarigold Is there a > at the bottom left of the page? If so that's where the profile is hidden and will slide out if you click/tap on it.
there's a + button..push it to get options...then select Profile...scroll down to find Report Lost / Stolen Phone
12-03-2023 06:50 PM
12-03-2023 06:48 PM - edited 12-03-2023 06:50 PM
use a laptop to log in to your account...then you'll see the Profile tab on the lower left side of page.
added,
