How to issue a ticket?
truckster
How to file a complaint
Meow
Go to chatbot (bottom right) and type Ticket. Follow prompts until offered to open a Ticket. Not difficult.
Yummy
Go to chatbot (bottom right) and type Ticket. Follow prompts until it offers you to open a ticket. Easy!
will13am
@truckster , if you need to initiate a support ticket, use the chat symbol on the lower right corner of the webpage.  If you wish to complain about this service, you can do so with the CCTS.
https://www.ccts-cprst.ca/
HI @truckster
what kind of help you need? maybe you can share here ?
To submit a ticket with CS Agent, try using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
