2 hours ago
My current plan is $15/month and has 3G data, but I saw Public Mobile had the $15 plan with 4G data. How can I upgrade my data speed to 4G in this plan?
2 hours ago
@Chalupa_Batman I’m aware OP can go for the 15GB for $30 4G plan too . But I said the $20 plan because they already on $15 plan so don’t need much data and. For $5 then they lay now you basically get 3GB you don’t already have and go up in data speed
2 hours ago
@Handy1 wrote:@JanetW2024 Forgot mention you most likely have this special offer in your account right now 3GB $20 4G plan
True. But you get 6GB data for $23 on the app. $1 a GB is good value.
2 hours ago - last edited an hour ago
The $15 100 minutes 250mb 4G is available only for QC new customers, it’s not available to any customers outside QC,
If you have a QC number, check if it’s availability for you to change subscription
2 hours ago
2 hours ago
@JanetW2024 sorry the $15 plan is gone ATM , You can only change to whatever plans are available to you in your account . And member it’s best to change plan with change in next renewal option and not immediately or you lose money on your current cycle
Change plan in 3 easy clicks
Once you find plan you want be sure to (change on renewal )So you don’t lose money on current cycle
2 hours ago
@JanetW2024 when you sign into your account, you can only change to what us showing as available. When you click on Change Subscription, if it's not there; that means you cannot change to it.
