12-20-2024 04:14 PM
12-20-2024 09:27 PM
You can check the ICCID on your phone setting the SIM card number.
12-20-2024 05:02 PM
if you are talking about the sim number on your phone already, the system can tell
12-20-2024 04:40 PM
if you're looking for the number on your sim...it's the 19 digit number imprinted on the actual sim.
12-20-2024 04:16 PM
login My Account and go to Profile page and you can get the sim card number there (you can do the same on PM app, just go to Account page)
https://myaccount.publicmobile.ca/en/account/profile/change-sim-number
