Need a puk for destroyed Samsung that took a ride on the roof of a car
whypublic
Have moved the sim to a used pixel but the pin number I used before doesn't unlock the phone. How can I get in or override?
@whypublic  if it’s a sim PUK unlock code support can help if it’s phone pin lock you will have to contact the carrier the phone came from or the manufacturer of the phone your now using
send  a  private message   To CS_Agent
@whypublic
Check to see if the used phone is Locked by a carrier or Blacklist as Lost/Stolen device.
https://imeicheck.com/imei-check
If it is a PUK for the SIM then contact a CS_Agent by clicking on the Chat icon then type in “Submit a Ticket” then Contact for an agent to help.
samsunga31
For a Samsung phone asking for a PUK on Public Mobile, you need either the SIM PUK from Public Mobile (via SIMon chatbot/ticket) or the phone's master unlock code from Samsung support (1-800-726-7864), depending on the exact message; check your original SIM packaging for the SIM PUK first, then contact PM support if it's a SIM issue, or Samsung if it's a "SIM network PIN blocked" error.
If the chatbot doesn't work, here's the direct link.
They will reply here.
