How to disable call forwarding?
mayan123
Hi,
I setup call forwarding for my number and I can't figure out how to disable it.
Can you please guide me since I can't find the answer on google.
darlicious
@mayan123
From @Nezgar 's post in another thread....
So.. here's the commands you can dial:
Query conditional no answer forward: *#61#
Set conditional no answer forward: *61*xxxyyyzzzz#
Reset conditional no answer forward back to Public Mobile Default: ##61#
Query conditional unreachable forward: *#62#
Set conditional unreachable forward: *62*xxxyyyzzzz#
Reset conditional unreachable forward back to Public Mobile Default: ##67#
Query conditional busy/decline forward: *#67#
Set conditional busy/decline forward: *67*xxxyyyzzzz#
Reset conditional busy/decline forward back to Public Mobile Default: ##67#
(Set or reset all three of the above at the same time using 004 instead of 61/62/67)
And lastly:
Query unconditional forward: *#21#
Set unconditional forward: *21*xxxyyyzzzz#
Reset unconditional forward back to inactive: ##21#
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here   ....for additional member supplied info.
JL9
Good to know, haven't had to use call forwarding before but I know if I did I would be the kind of person who wouldn't know how to shut it off lol
Nezgar
Dialing ##21# (or #21#) to cancel unconditional call forwarding will work on any phone, including iPhone and Android. The menus to accomplish this are just a fancier way to accomplish sending the same network commands...
mimmo
are you using ios or android?  the processes mignt be diffferent between the two in android
tap dial button then the three dots on top right then  settings thhen calls then call forwarding (pixel 6)
HI @mayan123   try   #21#
