11-28-2023 04:15 PM
Hello,
I am a new subscriber to Public Mobile and during the subscription process I chose the e-SIM option. I checked if my phone was compatible with e-SIM before subscribing, and it said that it was. When I paid for the subscription and proceeded with the activation through the Public Mobile app, it told me that my phone was not e-SIM compatible. I have a Samsung S20 5G and I saw some posts discussing a workaround which required using the US Samsung firmware, but I didn't want to go through that trouble, so I ended up purchasing a physical Public Mobile SIM card. I inserted the SIM into my phone and re-opened the Public Mobile app, and it's still showing that I can't continue with my activation because it is not e-SIM compatible. I tried clearing the app's cached data and reinstalled the app, but it still goes to the same page asking me to resume activation, but when I click to activate it tells me that my phone is not e-SIM compatible. I don't see an option to switch to a physical SIM on the phone app. I tried logging into my public mobile account through a computer instead, and upon logging in it asks me to "resume activation", and when I click to resume it just tells me to download the Public Mobile App to activate, and there are no other buttons or options on that page.
Thanks
03-27-2024 12:26 AM
In the PM app on your phone go to your account and find the option to enter a new SIM card. In there you can enter the SIM card number. Then close your app and restart. Everything should work.
11-28-2023 04:48 PM
Hi @e1231
Have you checked your SIM manager or the screen of your device to if there was a Public Mobile esim?
To make sure the esim associated with Public mobile is enabled along with your phone number.
If you are using an iphone:
Once you are done, click on "Reset all Networks". This will erase your wifi network but you can easily add it after.
If you have tried all this and it is still unsuccessful, please submit a ticket with our customer support team. You can do so by using the following link:
Please be sure to explain the issue to them. They will respond to you in you community inbox to check it from time o time. Due to high volumes, the delays for your ticket can be 24-48 hours.
11-28-2023 04:33 PM
Thank you for the assistance.
The phone is eSIM compatible but as I discovered through other forum discussions, the S20 5G Canadian version is loaded with a firmware does not have eSIM manager. I would need to flash my phone with the US version of the firmware, but like I mentioned previously I don't want to go through that hassle.
I will contact the support agent to help me bypass the page.
Thank you
11-28-2023 04:19 PM
So since you clicked eSIM your are stuck on that page. Your phone should be eSIM compatible so you should be good. Since you already have a physical SIM card then you have to speak to CS agent so they can help you bypass that page.
