How to check if my phone is compatible with an esim
Roche123
I got a new phone and what to transfer over my subscription to my new phone. Can this be done?
9 REPLIES 9
Roche123
Thanks that is most helpful. I will give it a try.
umnikke8
Take SIM out of old phone, put it in new phone, subscription transferred. Thats all there is to it.
If you want to switch to esim it's more work. But you can do that at a different time too.
hi @Roche123
so, you are existing PM subscxriber?
usually you just need to download PM app, login ,and choose email to get 2FA code (on the 2FA step, click Didn't receive code and choose email)
once you are in the app, go to Account page, and buy sim and choose esim
if you cannot login the app, then ask PM support agent to help
Roche123
How do I connect to my account. I can't access my old  phone to see the details if it is an esim or not. If I purchase a new esim will I have to purchase a new plan?
yes, iPhone 16 works very well. Just helped a friend to activate his account here with the phone
Roche123
Thanks! I checked with google it is compatible. It's a iPhone 16.
slusagm
possible, what phone you have?
and is esim critical to you? physical sim is not bad just in case esim does not work
HI @Roche123
esim usually not an issue with compatibility
it is more the network band the problem.  So, what phone do you have?
Chalupa_Batman
Hi @Roche123 Have you tried Google? Maybe the phone manufacturers website?
