How to change my pin
wenmin
2 REPLIES 2
If you just want to change it, you'll have to contact @CS_Agent for that.
If you NEED a moderator, create a support ticket:
Explain your issue to SIMON, seen below:
Use as few words as possible to allow the BOT to understand. Answer his questions until you get here:
Spoiler
Click on "Submit a ticket" and the Moderator team will respond to your concern, usually within 48 hours.
Alternatively, you may send a private message to moderator through the following link :
Contact @Moderator_Team
About @Moderator_Team
Moderator Hours
Monday-Friday: 8AM- 12AM EST
Saturday & Sunday: 8AM-10PM EST
ChuckYeah
@wenmin Did you forget your Pin Or just want to change it. IF you look back at your texts from Public Mobile, it will be the first or second one you got from them.
