08-14-2016 04:14 PM - edited 01-04-2022 03:01 PM
On "My Accout" It asked me to call *611, I tried, but there is no "change plan" option.
How do I change it?
Thanks
Service
08-14-2016 11:32 PM
IF YOU NEED to use phone OUTSIDE Canada, Roam Mobility is one of your Options for the time being
08-14-2016 11:25 PM
Add-Ons ONLY WORK within Canada
08-14-2016 11:22 PM
NO, PHONE will NOT WORK at all when in US, NO DATA, NO Text, NO Talk.
IF Wi-Fi is available, ONLY Way for 3rd party apps for communication when OUTSIDE CANADA
08-14-2016 11:20 PM
08-14-2016 11:19 PM
Also, Because PM has NO Roaming yet, US calls MUST BE MADE WITHIN CANADA, CANNOT BE MADE in US
08-14-2016 11:18 PM
Add-On remains on your account UNTIL you have it up, or UNLESS you fail to top up account 90 Days after account Expired
08-14-2016 11:16 PM
Add-On is separate from Rate Plan.
When you log into your Self-Serve account, you look for Add-On, this is where you can PURCHASE Add-On that has NO Expiry date
08-14-2016 11:15 PM
Add-On is not a subscription, its not part of a Plan.
08-14-2016 11:12 PM
08-14-2016 09:42 PM
No Problem.
Also, PM is Prepaid, and Currently Roaming is NOT available, But I feel in my bones that it might return one day
08-14-2016 09:38 PM
@makkahn28 thanks!
08-14-2016 09:32 PM
Hi. The difference is that with a Call Center, you talk Directly to an agent, and you can better explain the issues and perhaps get answers a bit faster.
Lack of call center only means use of Community private message and email support, slight delay, but it's up to the individual on what they prefer
08-14-2016 09:22 PM
@Luddite, another thing is that, if I move to the new plan, I heard someone mentioned about that I will miss to be able to call into customer centre, is that true? well, I never called in ever since first day. I am just wondering is that a real big difference for a customer's view?
Thanks again!
08-14-2016 07:24 PM
Thanks @makkahn28.
08-14-2016 07:21 PM
Hi. Yes, I am aware of your inquiry on that.
The answer is No unfortunately, Rewards collected while on GF Plan will NOT be applied retroactively.
When you begin your New Plan, ONLY then do you begin to earn Rewards that WILL then be applied to account
08-14-2016 06:26 PM
Yes you can purchase the US, though I would opt for International, long distance add-on to call across across Canada, AND to receive calls if you are out of province. Add-ons never expire until completely used so you can try it out and just see how long it lasts.
Sorry don't know how the loyalty reward is applied when you move off a grandfathered plan. @makkahn28 may know.
Do remember, PM provides no roaming; it only works within Canada. So you cannot use it in the USA, etc.
08-14-2016 06:05 PM
@Luddite oh, right! it's pretty much just $3 extra each month.
Beside you gotta pay 2 months of service upfront, this is a huge advantage to jumb the ship over!
btw, how about that $1 discount each yr we've been with PM? I am guessing I won't get that until next year?
One last thing is, if I change the plan to just include "Provincial call" plan, let's say if I go to Montreal, or U.S., is it possible to purhcase the $8 "add-on" before the trip so the phone will continue to work out of province or out of country?
Thanks
08-14-2016 05:57 PM
@sklin88 That's it. I assume otthers in your position are considering the change as well. If one is comfortable with no phone support, it makes a lot of sense.
You did notice that you will also get $6 off every 90 days if you use autopay?
08-14-2016 05:46 PM
the main thing that attract to me is the 6G data for each 90 days..
1G of data is not enough for me..
so for extra $5, I got 2Gb of data per month, so it's worth to make the switch, am I missing anything??
Thanks
08-14-2016 04:57 PM
Yes, you dial *611, and after requesting, they send an email to you, THIS IS THE FINAL guard if any cold feet. Just to forewarn you.
Choose carefully and wisely, my advice to you
08-14-2016 04:52 PM
Sorry @sklin88 didn't notice you asking "What do I do?". My understanding is that you dial *611 and speak to an agent; don't use the self serve features.
08-14-2016 04:49 PM
BEFORE YOU SWITCH, look at all angles to ensure that you know what you're getting yourself into.
New Plans have no Call support, only Email and Community support.
Aside from rewards, GF Plans can still enjoy the Add-Ons stuff
Plus, if 90 Day plan(s) you want are a bit steep for your wallet, then that can lead to buyers remorse.
Just to inform you of pros and cons, BUT choice is up to you
Plus, Once you switch, GF Plans are zapped to bed forever
08-14-2016 04:35 PM - edited 08-14-2016 04:37 PM
Correct. Grandfathered account holders have a special procedure to change their plan. This is to avoid "buyers' remorse" if they failed to notice that they CANNOT go back their old plan and wiil have NO phone support.
I believe you will get an email outlining this and must "sign off" before the change will be implemented.
Good luck.
If you have any issues come back here and we can engage a moderator.
![](/skins/images/813D49D689E0D681E39391EAB60FD666/responsive_peak/images/icon_anonymous_message.png)
