How to activate my new SIM card?
Jj15
Can’t seem to find the option on the website or app. I’ve already changed the SIM card number on my profile
7 REPLIES 7
@Jj15 wrote:
but my texts are showing up on others phone as coming from my email. Is there something I need change still?
@Jj15  To change this, try going to Settings > Messages > Send & Receive and configure the settings to start new conversations from your phone number.
edit to correct proper quote.
Jj15
The reboot worked thank you!
Jj15
I will try that thank you very much
@Jj15 wrote:
Yes it’s a swap. Lost mine and now put in the new one. I did use the method you showed and it recognized it as saved with the new SIM card number on my profile but I still don’t have service. Is there a waiting period?
thanks
@Jj15 , the SIM change takes effect immediately.  You should be able to do this in the app or on a desktop browser (use incognito mode).
@Jj15  Reboot the phone , if you have any other issues contact support
Message support directly
  • while your already here and logged in the community you can send a private message   To CS_Agents click >>>here.<<<
Jj15
thanks
@Jj15  Are you trying to activate or just do a SIM card swap from lost missing / damaged SIM card . If SIM card replacement you don’t activate it . otherwise you should be able to activate on the app
SIM  SWAPPING  profile tabs
